Originally Posted by 19963.4lsr5
Going that deep into it replace every rubber hose on top of the engine. Including the two coolant lines to the IAC as well as the vacuum line that goes from the IAC to the two sides of the intake manifold for the idle air assist or what ever they call it.
I had weeping heater hose lines from weak spring clamps. I also had a small split in the coolant line going to the IAC. Both of these caused dripping behind the engine. Plus I’ve also had a failed manifold gasket filling up the valley.
Or you could be like me and bypass the IAC altogether... not recommended for climates that see freezing weather.
