Originally Posted by Flynlow
Excellent, thanks for the resource... I picked up some 7 wraps. Stoked to get them in soon.
Originally Posted by JWaldz
@ rickashay
Addison, I don't know how I missed this thread. Congrats on moving back into the 3rd gen community. Looks like you're well on your way.
Hey thanks! Your truck continues to evolve. It's great to see and props for having it so long! How many years have you owned it?
Originally Posted by Yoter
Good to see you back in a 3rd Gen!
Is the idle still jumping around or has it stayed at about 700?
This might be obvious but did you clean you MAF and is it an OEM MAF?
I had an aftermarket MAF on my last 4Runner after about a year, the idle started jumping around in a similar manner to what you are experiencing. It also started after cleaning the throttle body. I ended up replacing both the IAC and MAF. I thought I had fried the IAC by cleaning the throttle body without removing it, but my inconsistent and high idle symptoms continued and finally an installing a new OEM MAF did the trick.
I look forward to seeing the build!
Thanks! The issue is now resolved. A combination of the washer mod, re-cleaning the throttle body and IAC, and letting the engine go through a couple startup cycles to figure itself out is what did the trick.
Originally Posted by Scramble
Woh! Looks like I'm late to the party, welcome back.
Yeeeewww! Thanks
