View Single Post
Old 06-03-2019, 12:03 AM
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
denso radiator is only 100 or so, also did you drain the coolant at the block too? i would bleed the system again, park on a hill and have the radiator pointing up, are you using toyota thermostat too? toyota coolant that is pre-mix 5050 pink?
Originally Posted by DCameraMan View Post
I feel bad posting this again since I've read other threads about this issue. I've looked everywhere and tried multiple solutions.
So the issue I get is after 2-3 hours on the highway, the temp slowly rises from 195º to around 205-208º. Right around the 208º mark the system suddenly stops cooling at idle. If I pull off the freeway and stop for gas, the second I come to a stop I quickly start to overheat. Revving the engine up to 3,500 RMP or so will bring the temp back down for a short time.
All driving up until this point is perfectly normal. Daily driving to work, no issues.. Driving an hour somewhere, no issues..
I've replaced the thermostat, fan clutch, water pump, and radiator. I cleaned the butterfly valve less than a year ago.
There seems to be some air in the system. I'll be burping it out soon. Sometimes at idle the heater will stop blowing hot air.
Next I'll get a new radiator cap.
I'll be cleaning my K&N air filter soon too. Installed 30k miles ago and hundreds of miles in dirt/desert.
The only thing I can think of is maybe the new radiator can't keep up after hours of driving. I read good reviews about the amazon cheapy radiator for $75 and decided to take gamble. Anyone here have experience with this? The new radiator is about 3/4 the thickness of the OEM I took out. It worried me when I did the install seeing the new one being thinner. Thinking that could be the issue.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
