Originally Posted by RS Dude
I would buy some new Densos off ebay for about $25 a pair. Also, with a soft metal brush, clean off the mating surfaces of the intake manifold and cyl heads before you put on gaskets.
that's what i bought. i plugged the valve holes with some painters tape and used a soft wire brush on a the end of a drill to carefully clean the mating surfaces. it cleaned up nicely and everything is back together. I just havent had time to get the plenums back on, refill with coolant, and test it. maybe this weekend i'll get to it.
i should also note that the recommendation in post #16 from gamefreakgc was spot on.
