Originally Posted by SendInTheCavalry
Could/should I consider a 1” taller front spring and increased capacity rear spring? Would I still have the clearance issues?
As others have said, you should have zero noise or clearance issues with your set-up.
To respond to what you posted above. If you add a 1" taller spring to the front of pre '19 Pro suspension you will be around 2" of lift. This is the route I went and really like the set-up, especially for the price. I added Bilstein 6112 600# 14" springs and got around 2.5" of lift, and 1.25" rear springs. Good luck and hope you get it figured out.
Paul
2016
TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
