Originally Posted by YellowSnow
Can you explain the 1, 2” bodylift options? For those of us running standard 2-3” coilover lifts, what option should we be ordering? Can you also list approximate labor hours to weld the front bumper together?
Yes! So those body lift options are only for if you have a body lift installed. If you have any sort of suspension lift, you will want to select the "no body lift" option.
Assuming the stock bumper is removed and the truck is ready to go, the front bumper takes about 4 hours to weld.
