Real Name: Jason
Real Name: Jason
Sorry guys for the delay, finally got to the springs yesterday. The pics show that the springs are very similar, and appeared to be a plug and play option. However, when I installed the 2018 springs, I found that the bottom of the springs are different from stock. The bottom coil is wound tighter than the stock springs and therefore didn't fit into the spring perch on the axle. With the amount of fabrication that would be necessary, I am going with the Moog springs.
The shocks do bolt up in the factory location, but I may have some issues with the top isolator under the top nut. It appears that I may not have enough threads available to get the nut started. With that being said, I didn't proceed since I need to wait for the Moog springs.
