Here ya go, post 34 it gets juicy...
Only KDSS w/lift need apply
"""Did some testing today.......... Pulling the fuse locked my kdss in highway mode, very stiff at 5mph and no change at moderate speed.... But! (With the fuse in) Unplugging the kdss module on the frame rail area locked mine in low speed mode!!!!!! So I could hit that 10-20mph and still have the more plush ride, the kdss dash light is lit up with either method and it turns right back off when plugged back in!, I can feel slightly more body roll on the road but I feel as if even though it stays in low speed mode and I get a softer ride, the valving in the system is only so big so at 25-30 it feels somewhat similar, but I also was testing with street pressure and it was a good test, can't wait to air down and have a day out on it... Driving into parking lots also felt softer on my typical run to the grocery store, so this will even help out the mall crawlers..����
Next is to wire in a switch to maybe the power wire going to the module so I don't need to take off the cover to change it, but it would really only be there if the kdss light gets irritating at night.""""
