Originally Posted by Akkording
@ rigtec
Are you aware of any potential switch solution without the manual undo of the harness?
Hi Akkording,
I think if I wanted to perform an experiment of
"Temporary KDSS disengagement"; there aren't a lot of wires the in convenient locations e.g., in the dash...etc, I might install a 'single pole/double through' (spdt) relay on the GND wire (White w/Blk stripe
"Stabilized ECU".
The reason for the SPDT relay, is because I don't know if the ecu normally operates when
Energized or
De-energized, so it can easily be switched around just by swapping one wire on the Normally Open, to the Normally closed terminals (or vice-versa)! I looked at a wiring diagram of that system but there are three ECU's that are networking together...
Main body ECU, Stabilizer ECU, and the Skid control ECU; which are using the four wheel speed sensors to control how KDSS is supposed to work! And like
Old Red
has stated, you don't want the truck to start throwing DTCs in the CAN-bus system! The
"Stabilizer ECU" has a Blk feed wire coming from the KDSS 10A fuse in the D/S fusebox!
This power source is HOT when in the on or start position. I might break the GND (Wh w/Blk stripe) wire, since our trucks utilize a
Ground-side switch mode! And even then you may start throwing DTC's because the Stabilizer ECU has lost power; that's why I refered to this as an experiment! Hope this helps,
'Best to you'
rig
