Real Name: Todi
Real Name: Todi
I received the full set aluminum skid plates and installed so far only the front and mid skids.
Few points:
- need bigger (external diameter) and thicker washers. As the bolt slots are designed for good reasons with tolerance, the washers sometime are too small
- for the front skid I propose to make the skid about 1/2' longer in the front to accommodate the OEM filler plate
- please post installation instructions on your web site so we can print copies
- need better instructions on installing the rear skid as it is not clear how to install those nuts with long handles... really need some help here
2018 TRD OR
- SSO Full Rack; Ironman 4x4 Stage 3 Foam Cell Pro: Constant Load – front, Performance Load – rear; M.O.R.E. aluminum full set skid plates; Artec aluminum gas tank skid; RCI front filler skid plate; HetfyFab Low-Profile Banshee Bumper; ReszFab flat sliders; Smittybilt 98695 XRC 9.5K GEN3 Winch; Pedal Commander; ARB diff breather; Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Wildpeak AT3W LT285/70-17 E;
