View Single Post
Old 06-13-2019, 09:55 PM
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
Originally Posted by Capnemo View Post
Mine was all apart when I bought the truck and I cannot find a DIY video or figure how to snap it back ....prior iwner drilled a hole and had a sheet rock screw
When I reupholstered my seat, I took that cover off. It was a pain to get off. I think I weakened the built in clips that snap into the rail on the side of the seat. I got it on but it wouldn't stay in place and sometimes when I sat on the seat it would pop out a little and push the seat button off its stem. I did something creative with a zip tie and haven't messed with it for years.
If I remember right there's 2 clips (like plastic hooks) opposite each other (molded part of the trim piece. They clip into the metal rail somehow. I think mine were spreading apart and allowing it to pop outward. I took a few wire ties linked together and when around the two clips once they were inserted and they keep the clips "squeezed" together. There's also a lateral clip in the end that you have to insert underneath the metal rail (or another trim piece, can't remember) before you push it on. Then I believe there's a small screw on the back. So all in all I think there's 3 molded clips and a screw in the back.
Sorry for the vague description. Going off of memory of about 2 years ago. Just make sure all the clips are there and not broken off or bent. When the plastic is bent it turns white where is was bent back or forth and usually is not as strong as it was.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
