Originally Posted by MyanRagahis
"So I left the negative terminal unplugged over night, lights are still up there.
Attempted zero point calibration, no go.
Well,
I took me several tries to calibrate the CP and YR too! I even moved the vehicle because the parking lot is not 100% level. Eventually I got it... AFTER I cleared the DTC using a techStream cable! You've gotta clear the history logs and temp files or else, N/G!
You don't need a techStream scanner to clear them. Just use one of the you-tube vids and follow; just be sure to find a good one, there are hundreds of bad info floating out, as you know! And Like
Old Red
stated, you've gotta get the steering wheel straight and be sure that the alignment is dead on!
After that, you should be fine!
'Cheers',
rig!
