Originally Posted by UrbanRunnerNY
If it is possible, where should i disconnect it? Since I'm doing this in the floor, is it ok that that the diagonal of the shock I am working on, suspension is compressed? I ask because i know XREAS shocks are connected diagonally.
Thanks in advance!
Here are the details on Xreas from the 03 FSM. Gives the details on teh disconnection points. As mentioned earlier you'll need all 4 wheels off the ground to close the system at the disconnect points and break the connection.
I'll second the remove the system and replace with aftermarket if you can afford to do so.
If you keep the Xreas and need the center sections I have a pair in the shed pulled in working condition when I removed mine at ~80k miles.
Free if you can pick up.
Boort
