Originally Posted by overlandout
I know a lot of people have said that. But, the 5ths are 2mm larger in hub diameter.
I have wondered if there's a minor change between two models that help that 2mm difference. I would say, stick with 4th gen rears so you dont run a risk of needing to throw out a set of new rotors.
Sent from my SM-G950U using Tapatalk
Here are the part numbers for the rear rotors that I put on my 06 4runner. 4243160311. You can look them up on the toyota parts website and see what they fit. I don't have a stake in what you use, just letting you know what I used on mine. I did use the 5th gen calipers as well, not sure if that is why it is said they will not fit. But I did my bakes all at once. There for I can not speak to whether or not you have to have the calipers in order to fit.
Here are the part numbers for the front rotors I used. Part Number: 4351260191 Supersession(s): 4351260190. As previously stated I used 5th gen calipers, Power Stop brand to be specific.
06 V8 SPORT, TOYTEC BOSS 2.0 LIFT, JBA UPPERS, DIFF DROP, SWAY BAR DROP & RELOCATE, 2010+ POWER STOP CALIPERS, ENERGY SUSPENSION BUSHINGS THROUGHOUT, URD OFF ROAD Y-PIPE, GIBSON STAINLESS CAT-BACK, URD FUEL PUMP WITH EXTERNAL FILTER, K&N, XD RS3'S NITTO 255/80'S & MORE
