Dying at idle
Hi All,
So I have an issue where when I've been running my 4Runner for a while, usually 45 mins + I will VERY occasionally stall at idle.
Here is the list of thing's I've done.
- New plugs/wires (not coils)
- Cleaned throttle body and ICV
- New Valve Cover Gaskets
- Cleaned MAF
- New fuel filter
- Checked Air Filter - did deckplate mod
- Removed slack from throttle cable and transmission cable
I don't see any obvious vacuum leaks, but having done the valve cover gaskets, I pretty much a lot of it unhooked and gave everything a once over, but I've not done anything comprehensive either.
Not getting any codes or anything. Otherwise, the truck runs like a champion, and even when it stalls, it starts right up and runs fine, so this is only a very mild annoyance.
Only happens when the truck is really good and hot. Never when cold. Only other thing I can think of is to start swapping out sensors. Looking for any suggestions/ideas.
1998 Toyota 4Runner Limited 4x4 - Black
1986 Porsche Carrera 3.2 Coupe - Guard's Red
2015 GTI SE - Tornado Red
