Originally Posted by Bigmd
Ok so it looks like a screwed up. I bought some 07 Tacoma 17” wheels off craigslist cheap and had them powder coated. Went to slap on the front and the offset is slightly different . About an inch or so. The tire is tucked a little too far in for my taste. I’m thinking 1.25” spider trax spacers should do the trick. Now for the rear can i get away with same ? Is the rear wider or narrower than the front? Any info is appreciated.
I believe they are similar width so the spacers should work for you on front and rear
I destroyed my T4R now the build is on
https://www.toyota-4runner.org/3rd-g...ml#post3301302
