See arrows. But to properly dispose of the system you should drain the oil from all the shocks and lines, and eliminate the gas pressure in the central accumulators. Disconnect lines from shocks and extend and compress shocks a couple times by hand to push all oil out. Get a drill bit and drill a hole in the end of the accumulators. Gas will escape in a moderate blast for about 1-2 seconds.
