Real Name: Ron
Real Name: Ron
Sometimes on these old trucks the outside of the crank pulley (the part with the timing marks) slips on the inside portion which is connected solidly to the crankshaft. The outer portion of the pulley floats on a rubber bushing (to damp vibrations), which can get old and allow slipping. If that happens your timing will look right but be wrong.
Best way to check this is to remove the number one spark plug, insert a wooden 1/4" dowel, and turn the engine until you have it at TDC. Then check the crank pulley timing mark to see if it matches.
Note: This has nothing to do with your timing belt. It only affects ignition timing, not valve timing. The fact that your distributor is rotated fully CCW to get 10degBTDC suggests that either your crank pulley timing mark is off (as per my suggestion above), or the distributor is inserted incorrectly.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
