Originally Posted by AuSeeker
Thinking a bit more on the hole you have it could also be other parts of the pressure plate as they have springs in the pressure plate but I would still think a bolt most likely could be the what cause the hole, it could also have been cause by a rock or similar being throw at the bell housing by a tire,
Thank you AuSeeker great info! I had time to pull the starter today and found the gear had split in half, only found one half and some shavings, so I'm thinking the other half might be behind the hole in the bell housing. Prepping to drop the transmission and get this patched.
