Real Name: The Native Explorer
Great install thread. I'm impressed at how well those mounted up with the factory brackets by just shifting them off to the side like that! Most guys I know that did this built custom bracketry or went crazy buying OEM stuff- that was a pretty slick install. Hopefully the lights output what you want- I am running into that issue on my cheaper "amber" LED square fogs.
I think the only reason you are getting flack about using wire nuts is that they aren't common in automotive use where vibration & the elements play a strong role in diminishing connections. To each their own!
"Bumble" '17 Lim w/ 35k, IVD Stage 7, CBI/Prinsu metal, Morimoto lighting, ARB Linx : Build thread in progress...
The AventuRunner Build '07 V8 Sport w/ DO armor, Fox squish, Falken rubber, IVD UCAs, BD lights, Sherpa rack -- gonna miss the V8
The "Iceberg" Build... Natty White 3rd Gen ----gone, but not forgotten...
IG @apohl17
From ye fellow @Konkordmusk... "The 4Runner does not drive. It simply rotates the Earth to your desired position."
