Originally Posted by andrew4r
I suspect the tape that comes with it will take paint off, too. I was considering putting some clear paint protector underneath. Does that sound like a good idea?
That is a bad idea. The tape would only be as strong as the vinyl you use there and it not a good adhesion surface. You just need to make sure you dont use the 3m tape that says “permanent bond”.
