Originally Posted by RotaryDreamz
After you topped off the brake fluid, you didnt clarify, but I'm assuming the brake fluid was low again afterwards?
Following the brake lines is pretty easy, and it will show obvious signs where the leak is coming from. After i did my TBU and bled the system, couple days later I decided to recheck everything, and sure enough I had a small leak from my hardline going into the caliper. Just tightened it up and no more leak.
I checked the reservoir and it really doesn't look like it has gone down much. I'll crawl under and see if I can see anything.
Sent from my SM-N960U using Tapatalk
