Real Name: Elliott
Real Name: Elliott
Originally Posted by charleypartanna
Hi folks!
My sunroof gasket on my 2008 Unlimited seems to leaking. I thought it was the windshield that I recently had replaced, but I had the leak evaluated by the shop and they showed me why they believe it’s the sunroof (which sounds/looks accurate to me).
The gasket is original (2008) and the California sun has undoubtedly taken its toll. It is shrunk on one side in particular which leads to water running into the channel. The leak only seems to occur during automatic car wash/dryer, but I would like to address it nonetheless.
Anyone ever replaced the gasket? If so, any tips? I’m handy and like working on my cars, but I’m guessing this job may be a pain and I’ll be willing to pay to have it done. Any other parts you’d recommend replacing as long as I (or someone else) is going in there?
Thanks all!
Charley
Pretty sure the gasket isn't your problem, there are four drain lines up there, one for each corner. If you are leaking from the sunroof, check the drains first, they can clog with dirt and leaves and such
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
