What engine do you have? 22RE? My truck is fine with 33x10.50s with the V6 auto and 4.30 gears. The 5 speed should be a bit better? Is your suspension original? I’m running OME and have lots of wheel well clearance. I’m not a fan of body lifts either, but if your springs are still original, you will probably want to upgrade them whether you go to 31s or skinny 33s. They do make a 32x11.50 as a middle ground, or if you go to 16” or 17” wheels the metric size options are huge.
‘99 UZJ 100 factory locker with OME and ST Maxxs
‘89 VN60 with OME and BFGs
