Originally Posted by Redthies
What engine do you have? 22RE? My truck is fine with 33x10.50s with the V6 auto and 4.30 gears. The 5 speed should be a bit better? Is your suspension original? I’m running OME and have lots of wheel well clearance. I’m not a fan of body lifts either, but if your springs are still original, you will probably want to upgrade them whether you go to 31s or skinny 33s. They do make a 32x11.50 as a middle ground, or if you go to 16” or 17” wheels the metric size options are huge.
The truck is a 3.0 with a 5 speed. Unsure on suspension, assumed oem.
