Love this mod, thank you for posting it.
Here is my setup.
Running Morimoto LEDs for both low and high. Then if course the DRLs where the high beams and pretty obnoxious.
I then did the Switch Back mod for the running lights, great mod. Bright white running lights are so much better than the stock DRL
Then I did the DRL delete mod to eliminate the high beam issue. But then I had to use the brightness adjustment every time at night.
With this mod I don’t have to touch the brightness at all anymore. I just switch between two setting, daytime running lights and headlights. Clean, simple, easy, and overall so much better in every way. This mod was the cherry on the top.
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
