View Single Post
Old 07-07-2019, 09:03 PM
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is just really nice Cymon is just really nice Cymon is just really nice Cymon is just really nice
Cymon's Avatar
Real Name: Chris
Originally Posted by axel1 View Post
I'll have to try upping the PSI a bit. I'm still running at stock 32PSI right now and BCM in that thread said that fixed his issue. Might go up to 35 and see how that feels.
I'm definitely not trading it in. If I can make it better that's all I need. A little wobble is fine but what I've got is the wheel moving a good 1-2 degrees in each direction at around 60mph.
I don’t know if it you checked around but when Road Force balancing make sure that the place doing it has a calibrated (some don’t calibrate correctly) Hunter Road Force balance machine. These tend to give better results.
With this and the correct equal tire pressure mine went from annoying to not noticeable.
I found the sweet spot with my LT tires is between 42-44 psi depending on load. I think your choice of trying 35-36 psi is a good starting point for something different.
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
