Originally Posted by FelixFJ40
Thanks, Mike, I've seen your products. They look great. The only thing holding me back is that the guy I spoke to at Sonoran Steel was adamant that with the sway bar extension brackets that come in their 1.2 kit (which I have), you need to use stock length links.
I can provide stock length links for the rear, and extended for the front. Or, stock length all around.
I don't think your links are tweaked. I looks like they rotated, and are most likely frozen in that position due to age and wear. If you remove the metal the washer you'll get rid of the noise since you won't have metal on metal contact anymore.
Mike
