I did this to mine when I put the lift on. I ended up rebuilding the suspension all the way around. From using both factory and aftermarket bushings my opinion would be this. For lower control arm, lower ball joint, upper ball joint, upper control arm, I would use factory bushings. The rest of the bushings, steering rack bushings, sway bar bushings, rear control arm bushings, I would use aftermarket bushings. Also, I would change the end links for longer ones. You can use the stock 3rd gen front end links on the rear sway bar as they are about 1" longer. For the front sway bar use end links from a 85 front sway bar as they are 1" longer than stock 3rd gen. If your going to reboot the CV-Axles, I would do the extended boot mod also.
