Originally Posted by kravi
Yikes, forgot to add. What about sizes? I'm not doing any suspension work (for the foreseeable future, anyway), but I'd like to maximize traction. Is there a recommended wheel size and tire size you could share, or should I stick with stock wheels and tire size?
Stock size is probably best for what you're after. Taller tires increase clearance but messes with your speedometer and power delivery (acceleration)...esp if the taller tire is heavier. Ground clearance does not seem to be what you need from what you wrote.
