View Single Post
Old 07-18-2019, 07:07 PM
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
Originally Posted by ggreyrunner View Post
Mobile1 then and still using it with Toyota oil filters. Less than 70,000 miles on it when the code occurred.
Good oil and filter selection, and 5K mile oil changes are more than adequate.
edit: here's everything you need to know about P0022: https://www.customtacos.com/tech.old...ta/0050013.pdf
If the error happens again, I'd:
1.) Remove and inspect the oil control valve filter (get a new $2 crush washer from the dealer to avoid leaks). If nothing significant is in there...
2.) Remove and inspect the oil control valve (use compressed air to blow away any dirt/abrasives from the area before removal). If no visible indicators of failure, e.g. spool valve moves freely with 12VDC applied, and seats correctly without voltage)...
3.) Either replace the oil control valve, or open up the valve cover and replace the VVT actuator and sprocket assembly with a new Toyota part. Flip a coin if that helps make the decision. The OCV is the more complex part, and therefore more likely to fail, and it's much cheaper & easier to replace than the VVT actuator...so I'd replace the OCV before tearing in for the actuator.
Let us know if you encounter the error code again.
waypoint is offline   Reply With QuoteReply With Quote
