Originally Posted by mrblah
the plate system offered a cleaner install. It doesn't offer any advantage over the turnbuckle system other than lightening your wallet.
I tried the turnbuckle method Didn't seem sturdy enough and ended up drilling holes instead.
For anyone interested....
I was able to use the 2 threaded existing holes that are meant for the slide-out tray (once I found them from underneath). I drilled the top of them out since they are covered with sheet metal. These holes helped a lot and allowed me to figure out where to put the other 2 holes I had to drill. Until I found these I was struggling on getting everything in alignment. I had to use 3 of the supplied spacers on each bolt to get the drawers high enough to clear the plastic over the rear wheels. This required me getting longer bolts from the hardware store which were 100mm in length. I cut square holes in the styrofoam liner and carpet where the bolts were coming through and put it back in. I added some 2x3 pieces to fill the empty space between the carpet and the drawers.
