Without poly body mounts in the back, the rear of the frame flexes a TON off road. That gap is needed to avoid body contact. If you see tighter clearances on other bumpers, they require poly rear body mounts.
Also, there isn't much to adjust. Unless they used a spacer on there, the bumper bolts to the bottom of the frame and can't be lifted higher from there...
$100/hr is a totally reasonable rate for custom work at a shop. Heck, its reasonable for normal work!
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
