View Single Post
Old 07-20-2019, 09:37 AM
ggreyrunner ggreyrunner is offline
ggreyrunner is on a distinguished road
Originally Posted by waypoint View Post
Good oil and filter selection, and 5K mile oil changes are more than adequate.
edit: here's everything you need to know about P0022: https://www.customtacos.com/tech.old...ta/0050013.pdf
If the error happens again, I'd:
1.) Remove and inspect the oil control valve filter (get a new $2 crush washer from the dealer to avoid leaks). If nothing significant is in there...
2.) Remove and inspect the oil control valve (use compressed air to blow away any dirt/abrasives from the area before removal). If no visible indicators of failure, e.g. spool valve moves freely with 12VDC applied, and seats correctly without voltage)...
3.) Either replace the oil control valve, or open up the valve cover and replace the VVT actuator and sprocket assembly with a new Toyota part. Flip a coin if that helps make the decision. The OCV is the more complex part, and therefore more likely to fail, and it's much cheaper & easier to replace than the VVT actuator...so I'd replace the OCV before tearing in for the actuator.
Let us know if you encounter the error code again.
Thank You for all of the great information. I have a feeling the error code will eventually come back again. Plan on keeping it another ten years. If so, i will let you know.
ggreyrunner is offline   Reply With QuoteReply With Quote
