Originally Posted by Kennysmoke
I need to swap my AC compressor, condenser and drier after my compressor seized last year and snapped the drive belt. Unfortunately my Runner is my only running vehicle right now and my time to work on it is very limited due to full time work schedule. I was wondering if I could change out the condenser and drier in the evening one night this week and do the compressor on the weekend then get it it vac tested for leaks and filled? Or do I need to do all the work in one shot?
I would suggest you get all the parts and do everything at once. It is not too terribly complicated. Once the system is open, the drier accumulates moisture (which you do not want. If you put on a new drier and then open the system again, it probably won't work as well....just my two cents....
