View Single Post
Old 07-29-2019, 10:57 PM
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
Originally Posted by thezentree View Post
Take the coilover out, connect the UCA, then put the coilover back in
same problem
when you put coilovers into a truck with an engine/body you can use the weight to compress the coilover and make it fit.
without any weight in the truck at all the spring needs to be compressed in place to fit.
you can only make the range of motion go so far and you run into the upper arm on the knuckle.
trust me that was my first config and the only reason I made it to this place is because I'm out of ideas.
I need to run to harbor fright tomorrow and grab a different spring compressor... I think a single action one specifically designed for front spring should do the trick. maybe.
