Originally Posted by leveeguy
Yes you will have to swap out the center tube from the plastic housing to the metal housing. You'll need to bend the center tabs slightly up, then push center tube down and rotate to remove it. Reverse directions to install into metal housing, then bend center tabs back down.
you don't need to bend the tabs to get the center tube out. There are instructions on the Trail4runner site that explains how to push down on the top of the tube then slide the bottom or something like that. Mine came right out.
