Originally Posted by Makakilo
OK a quick follow up. I got the tires installed 2 weeks ago and wheels aligned. When I left, everything felt fine. When I hit the freeway, it pulled to the right and the wheel shook at 55mph or so.
I took it back to get realigned the following Saturday and the tech took it for a drive, came back and made some adjustments. Took it for another drive and came back to make some adjustments and continued 4-5 times over 2-3 hours. After all of that, it no longer pulls and the steering shakes a little at higher speeds. Overall I'm happy.
What kind of tires do you have? are they nearly bald, brand new, or somewhere in the middle? Have they bene road force balanced? the vibration issue definitely sounds like a balancing problem
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs |
5th Gen Brakes | Everything else is in the
Build Thread
