Real Name: Andrew
Real Name: Andrew
For a quick, easy potential solution, I'm thinking of running the ratchet strap through the side handle, underneath the crossbars, and up through the other handle. This probably won't limit horizontal play, but it will get the strap out of the way when I have the case open.
Each end has an additional 2 slots for straps, so I may use some tie down straps in the front (the front has the most play because of how far the ratchet strap has to extend out in front for room to ratchet).
@andyadventuring @samadventuring
'18 TRD Off-Road
