Originally Posted by thezentree
Buy a gas bottle if your welder can run gas. I did mine with flux core and spent WAY more time grinding slag off of things than I needed to. It took me two solid 10 hours days to get mine done. Fitting the tubes up takes a long time, especially if you haven't done it before. That said, the plate parts fit together like a Lego kit.
Oh, and if you haven't welded those nuts to the middle plate on top of the frame rails, make sure you take the bolts out before you weld the winch plate on.
Totally true. But flux core hits like a hammer, which is nice if you can only afford a 110v machine like me back in college
