A lil help... perfect alignment but pulls right
Happy Friday to all!
Looking for a bit of help or suggestions. I have a 2012 Limited with Eibach lift, JBA HighCaster uca's, level8 rims and Falken AT3s.
It was lifted in Jan and was fine until recently.
I have had it aligned twice at two different shops now and alignment is good.
However, it pulls right when you let off the accelerator.
I have checked the front brakes (removed pads and rotors and cleaned everything up and put back with new pins and springs). Dealer replaced drivers side wheel bearing over 2 months ago but pass side is original.
No play/noise from CV axles etc...
Edit: Front tires are NEW and have been swapped side to side and pull remains to right when let off accel.
Any ideas?
Thanks
X
