Originally Posted by f250ben
This is helpful, and confirmation of what I just found. I did some research on the A340F transmission (which was in the 1st gen tacomas, 3rd gen 4runners, and the 03/04 4th gens. Most of the fluid checking instructions specified engine running.
Same for every automatic transmission with dipstick I've ever seen including GM, Ford, Subaru, etc. Engine running at idle, transmission at operating temp, vehicle level.
It looks like my trans was underfilled.
Also, MaxLife fluid's hot viscosity is on the low end of the spectrum for your transmission. Yours calls for T-IV fluid which is thicker than WS...MaxLife claims to meet both specs. If you find you're not happy with the upshift or downshift behavior, consider exchanging for T-IV spec fluid.
The data below are gathered from manufacturer product data sheets, and show the significant difference in viscosity between MaxLife and Castrol's product which meets T-IV spec but not WS:
Product 40degC visc / 100degC visc / Viscosity Index
Valvoline MaxLife 28.82 / 5.91 / VI 156
Castrol TransMax Import Multi-Vehicle 36.6 / 8.0 / VI 200
