View Single Post
Old 08-05-2019, 08:08 AM
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Originally Posted by nobb View Post
The 8" pre-made length available at any local parts store also fits. It is extremely easy to bend this front line. Just buy 2 or 3 lines if you are nervous about messing up...it will still be cheaper than buying the OEM part. If you are competent enough to do your own hard brake lines, chances are bending this will be no problem.
I just ran into this over the weekend, broke a line doing brakes. Could only find parts store lines with extended bevel on both ends, see the pic on the OEM line has the caliper nut as full thread. So I did install the generic ones from O'reillys but could only catch a minimal amount of thread on caliper. It works but just very barely, so was planning getting a couple oem hard lines. Where are the generic lines available with one side bevel end and one side full thread? Or not sure if full thread both sides would work. I favor oem, but good to know alternative in pinch.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
