Originally Posted by JPK_NJ
Well chalk me up as another 19' KDSS issue. Since my initial dealer fix didn't work, driver side bushing replaced at 500M, they're now planning on full sway bar/bushings/end link replacements.
2500 miles on truck but have had C Rated BFG K02 tires since day 1. Something about it just makes think stiffer tires are causing extra force/stress on the suspension components that were engineered with the give/flex of P rated rubber.
Hoping other member with KDSS problems can chime in and indicate what tires they're running. I might go back to P rated tires when my truck is hopefully fixed on Thursday.
E rated tires on 2.5" lift zero issues other than occasional squeak from the bushings where it bolts to the LCA...makes sense as they're at an angle they weren't designed for.
