Originally Posted by tm965
if you dont need the added durability of a c load tire, then i dont see why you wouldnt go back to a P rated tire for the reasons you mentioned. I had g1s on my previous car and i like them fine--they were quiet and were an upgrade from the goodyears that came on the vehicle for sure.
That's kind of what I was thinking. The KO2 is really overkill for what I need... hindsight is 20/20, right?
Originally Posted by Tejas
We had G2's on our 2015 5th Gen and it was by far the sketchiest tire I have ever driven in the rain with, they were absolutely horrible in the wet. Light weight, better fuel economy, great on the road, yes, yes, yes, but I wouldn't run them again even if you gave me two brand new sets for free.
We run KO2's on both of our vehicles, they have their drawbacks, but they are still one of if not the best all around tires on the market when you factor in durability, mileage, off-road and on-road traction, price, availability, looks etc. Pick your poison but I think there are much better options out there than the G2 and the KO2 is certainly one of them.
Yikes. That's scary sounding, though I have read people say similar things about KO2s in the wet. Because the Limited is full time 4x4, I think I've experienced less wet traction issues than some of the folks with SR5s, ORs or the TRD Pro. I have not been in a position yet where I feel sketched out by a lack of wet traction on the KO2s, but I will say that braking in general is a bit more dramatic with KO2s vs. the Yokohama Geolanders that came stock... more nose dive, and it seems like the ABS is constantly triggered. Do you experience that also?
Originally Posted by KuhDunkADunk
I hate my KO2s. Can't wait to replace them. They still have plenty of tread on them but as soon as the rain season starts, I'm changing them to something much more forgiving on wet roads.
Out of curiosity, what do you hate? Sounds like bad wet traction?
Originally Posted by jdhunz
What about the General Grabber A/T-X? I've considered swapping those from the the stock Bridgestone/Dunlop that will come on my '20 TRDORP along with the TGG2s...
I've read about this tire many times but have not done a ton of research. I'll add it to my list. Thank you.
Originally Posted by MAST4R
First, P vs LT.
People say that all the time. Except those of us who actually use P-metric tires all over the place with rare issues.
Yes, you are more likely to lose a P-metric, but P-metric tires hold their own very well at or near street pressures. You can play with 28-33 psi depending on need, etc, I just normally use 33 on and offroad, but actual airing down should be limited to deep sand and similar.
Using a P-metric tire gives you a better tire literally 99% of the time. Unless you plan on driving difficult obstacles made of sharp granite in AZ or equivalent, there is no point in going LT with a third ply in the sidewall. Just going LTC is not necessarily a guarantee about anything here in AZ.
For most people, getting LT tires on 4Runners is the equivalent of getting a 4Runner to drive a fire road once in a blue moon. Total overkill.
Second, not all P-metric tires give you equal shot at strength. I have not been able to find anything conclusive but here is a list of P-metric tires that make a case for themselves in the strength department:
Goodyear Adventure with Kevlar, for Kevlar in the tread and "durawall" sidewalls.
Falken Wildpeak AT3W for high ply turn-ups simulating 4 ply sidewall and strong shoulder protectors
Nitto Ridge Grappler for strong shoulder protectors
Wrangler Duratrac for strong shoulder protectors
Wrangler Ultraterrain for strong shoulder protectors
General Grabber ATX for strong shoulder protectors
That's about it. All other P-metrics I can think of lack the strong shoulder protectors necessary to keep rocks at bay.
Third, rain and wet.
Look at Discount Tire Direct and search by vehicle and then select tire and then select Treadwell. You will see third party testing for stopping distances in dry and wet.
Best dry and wet braking
outstanding dry and wet braking:
Wrangler Trail Runner
Wrangler Adventure with Kevlar
Falken Wildpeak AT 3W
All three of these stop within feet of each other.
For your needs, I recommend the tire I use, the Wildpeak AT 3W. It is cheap in 265 70 17 yet great on and off road, does great in the rain, I have total confidence in its strength everywhere outside the Sonoran Desert and equivalent, and does well enough even in those harshest environments.
My rear tires are 7/32nds now and had no issues with all the Montana rain we experienced in July. They still perform very well offroad as well.
The tire makes no noise in 265 70 17 (can be noisier in 285) and is very comfortable. Only now, at 7/32, I am starting to feel a slight loss of comfort, which happens to all tires when tread gets shallower.
Great post. Thank you so much for your insight.
