View Single Post
Old 08-07-2019, 10:52 AM
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Originally Posted by jicko View Post
As the price of a set of 2019 TRD Pro suspension is similar pricing to a comparable set of Fox 2.5..... I am considering putting that onto a 2015 SR5
Now, what rear spring should I use?
Any info on what rear spring a 2019 TRD Pro comes with? (Are they just STOCK?)
So, the new TRD Pro don't have much "lift" as it come stock? Can it be adjusted?
Isn't the whole point of the TRD Fox suspension that it is an internal bypass suspension? Isn't it position sensitive? If so, shouldn't it be run with no lift? It is not a normal shock that would just sit a bit off with a 1" taller spring in the rear.
One way to verify is to search whether any such shocks are offered with a range for lift (like 1-3 or 0-1.5 for regular shocks) or with just a fixed lift.
