Originally Posted by beklemmung
Here's a pic of the rear passenger side wheel, where I suspect a leaking axle seal.
That's not a little bit of oil, the entire backside of the wheel is wet. I would advise doing the whole deal, so new bearings & inner seal along with brake pads. What happens is the gear oil passes through the non-serviceable bearings and washes out all the grease which ends up in the rear drum. The bearings will be fine at first but will fail prematurely.
