Originally Posted by St Runner
I put a 97 whole rear axle (no locker) into my 2001 which had bad bearings when I bought it. I figured out the brake lines but never got the trac and abs to work properly. The sensors fit but its my impression they are not compatible. I ended up pulling the abs fuse which is no problem for where and how I drive. I thought about changing out the individual side axles to see if that would solve the problem but recently got a 2002 whole rear axle which I am going to put in. My suggestion is if you want the locker just modify the axle housing to fit the locking diff
Ugh, if the sensors don't work that alone is like $400 in parts, which makes a strong case for modifying my 01 housing.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
