If you have a 4WD, it's worth noting that the front diff holds way less oil than the rear, and the front oil will likely be much dirtier than the rear. The front plug can be very difficult to remove - be sure you can remove the fill plug before draining. Seem many (most?) people never change the diff or transfer case oil, but given the relatively long change intervals it's very inexpensive insurance, and an easy DIY job.
--o-------o-
2008 4R Limited. Mostly stock and runing great!
