View Single Post
Old 08-09-2019, 10:29 AM
mesooohoppy mesooohoppy is offline
mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about
Originally Posted by sleepydad View Post
don't you get an airbag warning light or code?
I guess if your swapping out a non air bag wheel you just remove the light bulb and ignor.
you will. you will need to wire in a resistor or buy a delete kit (which is basically the same thing).
Originally Posted by Mzs14 View Post
The momo hubs shares spline counts across the Celica, Corolla and other common Toyota’s.
If you do install this on an airbag equipped vehicle you need to wire in a 1.3 ohm resistor to not disable the passenger airbag and prevent an airbag fault light from occurring.
thank you for the measurement of the resistor, i was going to buy a kit with a different resistors and try my luck that way. do you recommend buying from a certain place? how many watts do i need? 1/4W?
99 4runner limited; imperial jade mica
IG: mesooohoppy
mesooohoppy is offline   Reply With QuoteReply With Quote
